01.09.2010, 12:33 AM
HA! DOH ! I know this,wasn't thinking, STUPID ME !
Believe it or not making servo bakes work I can figure out ? It's just that the M.M.M. ESC with 6s and ESC brakeing kinda scares me cause that seems to be issue for a LOT of failures. But def the simplist way out. I will have to reconsider servo brakes and try 6s w/ESC brakes I guess.
I think I'll elect to start with a M.M.M. and a 1717 w/6s with ESC brakes and experiment from there. Sometimes simple is better. Once I have it all together and see what the weight will be finished will also determin if I need to juice up to a different combo or higher voltage. I can always use this combo in something else if i find it less than ideal in the 5T Savy.
I thank you for your time and input James, Your word here is highly valued and greatly appreciated.
Planned on useing HC 6s 40C for the build. How you likeing yours ????
I have not had a chance to run my HC 5k 40c lipo yet... Finally got the battery tray made and just need to wire it up and give it a try with the 1717. If it meets its specs it was a steal, under 100 bucks for that kind of power!
I planned to use lutach's 10s esc for my 5t build, and run motor brakes. I have some 3200 30c lipos, enough to do 10s2p... I will try to keep the weight down, may even integrate the chassis with the roll cage, like a full tube frame...
As far as my info being highly valued... well if you say so! Just glad I could be here for you to bounce some ideas off.
For the record I have run quite a few MMM 6s setups with motor brakes and it seems to do fine. I usually run 50% brake force, plenty to stop a lst or a muggy! So it should have enough brake force to stop heavier stuff. I can't wait for the 8s monster, hope that is still in the works. That and a 1300kv 1717 or 1721+ would be gangster!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.09.2010, 01:40 PM
Thanks Again
This is good to hear. On my LST's w/5s I usually run about 35% brakes so I reckon I'll be OK.
The 8s Monster would be welcomed for sure !!!
