Beanie
01.12.2010, 03:57 AM
Yeah, my current 7/7/3 is feeling great round 180 corners as it really turns well but also when I need some punch then it feels a little lacking and also seems to lack a little drive down the straights. To be fair the oil is about 6 months old inside the diffs too which means they are bound to have broken down to a lighter grade equivalent.
I'll try refreshing them with 7/10/3 and see how that feels.
I have a front Smartdiff for the 8T, I'm guessing by putting the spur gear onto it then it could also be used in the centre? Would that work? Any recommendations on the best springs to use in it for racing a 8T 1.0 BL?
Beanie
01.18.2010, 06:49 AM
Any idea on the smartdiff enquiry guys?
Also, if after a run then my battteries and ESC are warm but my motor is noticeably warmer, not roasting, then from the info on here in the FAQ section would this seem to suggest that i'm undergeared? Running 15/48 in the 8T, change up to 16/48 do you think?
bryan
bryan's Avatar
01.19.2010, 10:16 PM
I run smart diffs in my 8T 2.0.Smart diffs will make a difference all around the track. steer around the track on power w/mmm-1700kv-5s-15/45.Nice upgrade in my opinion.
Beanie
01.21.2010, 06:10 PM
Well I'm going to order a 16 tooth pinion and try that for now and see what happens. Also try some more toe in and anti-squat at the back
