01.13.2010, 12:23 AM
However you do it make sure that you drill a hole in the corners. 90 degree corners are weak spots asking for problems, plus the radiused corners look better. It's not a big area that needs to be removed so if it was me I would drill two holes, one at each end of the slot, pick a bit that is slightly wider than the spur gear and then use a dremel to remove the material between the holes
+1. That's exactly what I would do...
Bazzokajoe
01.13.2010, 03:02 AM
cool cheers guys :)
now i have another question... when converting to electric do any of you fill in the nasty nitro holes (flywheel/engine mounts?)
if so... with what?
01.13.2010, 03:52 AM
Originally Posted by Bazzokajoe View Post
cool cheers guys :)
if so... with what?
I have never seen the holes filled...........
Bazzokajoe
01.13.2010, 09:54 AM
ahh ok, i just thought it would probably look alot better , i guess i will see next week, when all my parts are supposed to be arriving :)
