01.16.2010, 10:25 PM
Originally Posted by Helly View Post
for the hub, i forget to add this pic: (it's just 23mm hub with around 0.4mm plate to add the extra 1mm!
1st time I have seen this done, but I have thought for a while that it would work fine. Just finding stock that is the correct thickness, looks like brass shim stock you are using?
