Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.18.2010, 10:48 PM
Originally Posted by Chadworkz View Post
That's cool, I was just trying to help.
You might want to try a stiffer spring, like Purple, since you have the pre-load cranked way down. Like I said, a longer spring of the same weight does absolutely nothing different than the shorter spring of the same weight except stop you from cranking the pre-load so far down.
Pre-load is ONLY for adjusting ride-height, it does not make the springs/suspension stiffer, you need a stiffer spring for that.
The preload is not cranked "way down", 1/4 of the threads down at best as mentioned.
Don't want a stiffer spring, thats why I was happy to hear of the double orange at the lb it was.
Fully aware what the pre load is for.
Thanx Sweet cheeks
bryan
bryan's Avatar
01.19.2010, 09:58 PM
Thanx Sweet cheeks
Dont bash anotha brotha set-up
