A RC Dude
A RC Dude's Avatar
01.25.2010, 07:10 PM
wow, thanks for the info guys!
and yes i've let my lock-tite dry for about 24 hours every time. it is however a few years old but still can be hard to remove sometimes. i think i'll buy some red lock-tite when i go to town next time. but the set screw in the tranny that came out is pretty ground down on the bottom so i'm going to need a new one in order for it to grab well on the round shaft.
Try using the info provided
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Try using the info provided - 01.25.2010, 07:30 PM
What BG said was to grind some sort of locking point into the shaft itself. It is best to have some sort of dig point on the shaft for the set screw to tighten into. Then it will hold up better during operation.
Loctite is one of those chemical miracles of a sort. I attended a class for loctite a few years ago while working at Universal Studios Orlando, and what the company told us then was that their product actually hardenes up under pressure when you apply a tightening force to the hardware it is applied to. It does not dry because of the air around it. Of course it will harden up or cake up over a long period of time, but that is not the purpose of using it. You can even apply it and put the item right back into use, but they suggested that you let it cure for at least an hour before using the item. None of the lictite products is really permanent, but as noted one loctite product is stronger then the previous one as you climb the ladder. We used loctite on everything for putting the rollercoasters back together at "Islands of Adventure". I worked on the Dueling Dragons, The Incredible Hulk, and the Mummy coasters, and without loctite they would have come apart farely easy under the pressure of normal operation.
SUPERMAXX YOUR LIFE.
A RC Dude
A RC Dude's Avatar
04.02.2010, 09:40 PM
Thanks guys! and i haven't had any problem for a wile now
haha that's awesome! i love the roller coasters in those parks and i'm actually going to be their with a big group of people this coming friday and saturday! should be fun, it's been 2 years since the first and only time i've been their lol
Love it.
JERRY2KONE
JERRY2KONE's Avatar
Love it. - 04.03.2010, 04:26 AM
Yea I loved that place. As a part of my daily duties when working the third shift I was always happy to ride each and every coaster every morning before the park opened up for the day. It was one of our requirements for checking the sounds of the cars and the track. Once you get used to how everythign worked it was quite easy to hear if anything was out of wack. Not to mention that it was hella fun for me. One of my nightly PM's was to do the "walk through" track inspection of the entire ride, which always included finding at least $30 to $40 in change and bills laying about the ground from the cork screw or one of the other inverted turns. Plus the jewlery, cameras, Oakley sun glasses, and other stuff lost on the ride. Everything personal was turned into lost and found, but after 30 days was turned back over to us if not claimed. Some guys just did not enjoy the rides, but it was always a blast for me. My girl(now my wife) used to call me early in the morning to check my status and I would chat with her while testing the rides. Pretty cool job, and the pay was not bad either. All in all a good company to work for.
