brushlessboy16
brushlessboy16's Avatar
01.28.2010, 11:55 AM
dunno, a center diff out of a nitro buggy would have the dual brakes needed. Dog bones to drive dogs, voila.
An idler between the diff and motor so the motor could lie beside the diff.
Lotsa options.
who said you need an idler, smack a 48t mod1 spur on an outrunner motor.. just reverse the rotation.
IF, i could i would mount the diff in the rear of the vehicle. run straight output out of the diffs, run a short shaft for the drive gears. then use a long shaft collar to connect them... Ill look into it and probably mock it up :)
