Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
Moller123456 !
06.24.2010, 05:33 PM
Originally Posted by shenri View Post
Anyone have a spare chassis they can send to John at MoosRacing? http://www.moosracing.mono.net/
I sent him an email about a custom length Ten-T chassis for Short Course, he said for $100 he could make a custom chassis, he just needs a template to start with.
I would like some general concensus on the exact lenght the chassis should be streched, or even if this project is worth it...
Droop screw plates would be a nice addition too, and maybe only the holes for Mikes battery tray (nitro delete).
Here is the thread on the Hyper 9 that inspired me.
I live in the same country as john, but the chassis is in use XD Will ofcause do it if i get a free carbon chassis XD
  Send a message via MSN to Moller123456 !
XXXDAD
XXXDAD's Avatar
Thumbs down 06.24.2010, 03:04 PM
Originally Posted by Moller123456 ! View Post
http://www.youtube.com/user/mollis123456 More video's of the ten-t :)
Now I know why your center Berings are going out... you drive in the most HARSH condition available.. big rocks and fine sand.... nothing will last! Have fun!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
Moller123456 !
06.24.2010, 05:34 PM
the bearing was because of the motor mount, but f... it.
Been to a rc meet up today, and the battery/esc tray fell out again!!!!!!!!! So fuc*ing pissed
XXXDAD
XXXDAD's Avatar
06.24.2010, 05:38 PM
Did the incerts come out or did you loose the screws?
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
Moller123456 !
06.24.2010, 05:44 PM
well was held by 1 screw... the gold things the screws go into stayed with the screws.. so bad making once again + the motor mount is bent.
How much pain do i have to go throu before mike shippes me a new conversion kit? It must be clear to the blind eye that my kit has not been made as well as all the other ones? or do all you other people drive slower than nitro cars?
nitrostarter
nitrostarter's Avatar
06.24.2010, 01:47 PM
If you have a Ten-T, take yours apart and send it to him. Sacrifice a little to gain a bunch...
N. Rustler conversion
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
06.25.2010, 12:13 PM
I agree with bryan...
-Chad
PM ME IF YOU HAVE THE BELOW:
timaneli
06.27.2010, 11:22 AM
i am thinking to convert a losi ten of these and run it with vxl combo on 2s only.
will run good on 2s lipo?
you are what you race!!
gone banana
06.28.2010, 09:11 AM
hi guy i got pictures of my ten-t E on rctech i have pro trac rims got an rpm bumper for sc10 20.00 test drove it sunday with a little tuning it while be the fastes 4wd out there
i will put list of thing i did tonight
Topsy Kretts
Topsy Kretts's Avatar
06.29.2010, 11:21 AM
Thanks Yeah I'll check it out, I waited a while before I bought Mike's conversion to see if the 4x4 class would keep up with the 2wd class. Well it seem to be catching up with 2wd I Love this conversion I used a 1509 1.5y/f Neu motor geared at 54/17 with a MMP esc with 0 punch control to start, HOLY CR&P Batman this thing is the bomb The nitro set-up has nothing on this!!!!!! Temps were just warm to the touch,not worth putting a gun to, that is using 4200mah 4s packs. Diffs are 5/7/3 but may go to 5 in the center to get a bit more steering,really have not played with the shocks yet.This puppy has a ton of potential,and its built as heavy duty as any 1/8 scale out there If you are on the fence about this conversion kit,time to climb off Best money I have spent on RC in a while!!! Thanks Mike and all you Guy's that help point us in the right Direction.
gone banana
06.30.2010, 07:43 AM
sorry for the delay
ID:	9088   Click image for larger version
XXXDAD
XXXDAD's Avatar
Lightbulb 06.30.2010, 09:55 AM
sorry for the delay
So are those the Proline rims they look great... what wheel lugs did you use?
Did the front bumper bolt on or require mods? What bumper for the back? Details Please great job!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
gone banana
06.30.2010, 03:07 PM
i use proline pro trac rim the bumper are rpm sc10 it come with the rear i redrilled the for the front and used the chassis heated it up to bend a 90 in it
line up with line diff case and drilled and tap 2 4 40 flat head to help support the got small alum. tube tap both end to help from flex
ID:	9091   Click image for larger version
ID:	9092   Click image for larger version
Topsy Kretts
06.29.2010, 11:29 AM
Man, because of the weight of the truck I think you would be tax that set-up too much and burn up your esc pretty Quick
XXXDAD
XXXDAD's Avatar
07.01.2010, 01:24 PM
Oh! How about heating up the pin and melting it into place... use a pair of lock pliers needle nose. heat the pin and brand that baby into the slot... ??? I didnt know!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
