Calibration problem
crusey_aus
01.31.2010, 06:26 AM
Hello folks,
Just to let you know I have the same issue trying to calibrate a Spektrum DX3S with a Mamba Max
V1.21 works fine but any later will not recognise throttle or brake when running the setup
Changing EPA's does not make any difference (when set at 100% on v1.21 it works fine)
Looking forward to a fix as I would like to try the later vers that allows programming through the servo lead rather than the usb port
Cheers
crusey_aus
2
Beanie
01.31.2010, 07:58 AM
Originally Posted by
crusey_aus
Cheers
Hmm...does that mean that using the MMM ESC firmware v1.21 will not allow me to use the castlelink to programme it?
Beanie
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
Off
