Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
02.01.2010, 12:07 PM
...Another upgrade I'd like Losi to release is an adjustable rear toe plate. The rear has too much toe-in for me since I bash mostly. The stock toe plate is just a piece of metal with a hole for the pin - no plastic insert so you can adjust them. Besides, with the toe-in as far as it is (in the rear), the shocks are at a vertical front-to-rear angle. Reducing toe-in will bring the tires a little further back and make the shocks align better.
Well, I created my own rear toe plate out of some 6061-T6 yesterday. The stock plate is steel, so I hope the aluminum version holds up. My version is not as pretty, but I definitely like the way it looks better; the a-arms are not as swept forward, less rear shock angle (front-to-rear), pushes the rear tires back about 4-5mm, and decreases the toe-in. The hinge pin holes were moved in a hair less than 2.5mm on each side.
