02.04.2010, 06:45 PM
I didn't read the whole thread, but I have a couple Quark125B's and they are pretty smooth. They do tend to run warm, but that's nothing a little modding, a couple caps, and better heatsinking can't solve. I have always been a fan of Quark because of their smooth starts, but now that Castle has tweaked their software quite a bit, I find the MM/MMM/MMPro is just as smooth as the Quark.
If you haven't already done so, I would disable the LVC completely and try it. That will eliminate any chance of the batteries dipping too low. Also, I would try different batteries as well. I'm not a huge fan of Maxamps due to their real-world performance (I speak from experience) in even a gentle setup; 4s 5Ah 20C pack in a 2WD Slash on a 2200kv motor geared for ~35mph should NOT cause the batteries to get hot. Anyway, if it still stutters, I would start suspecting the ESC.
FYI: despite the 125A rating, the Quark 125 is roughly equivalent to the Mamba Max (regular one) current-wise, so I would probably equate the 80A version closer to that of a Sidewinder, or maybe a tad more. So, if it turns out to be faulty, a MM might be a good choice for replacement as long as you are running 4s (with BEC) or lower.
sikeston34m
sikeston34m's Avatar
02.04.2010, 06:51 PM
If ESC replacement is in order, the Mamba Max Pro would fit that truck up VERY nicely.
It would also allow you the option to go up to 6S if you chose to do so.
