Metallover
RC-Monster Spudgunner
Metallover's Avatar
02.08.2010, 09:44 PM
The esc is good but the motor is too big. The medusa motor is way better then the castle motors, but if you want a castle motor the only ones that will run cool are the 28mm motors, which I know nothing else about. The 1/10th motors are 36mm in diameter and they won't fit without serious modding.. The 28mm motors by castle are made for 1/18th scale vehicles like the vendetta.
Stick with the medusa and if the esc is getting too hot, upgrade the the 10th scale sidewinder. If the motor is too hot you are geard to high, or possibly too low. You may also have binding in your drivetrain.
