02.15.2010, 04:07 PM
Finn- it is intended for m3 screws, nothing a little dremeling won't take care of. It'll fit 52t spurs, but as you mentioned there would need to be spur clearance cut beneath it or it would have to be spaced up.
Everybody- stock is gone I'm glad Mike moved them and we weren't lying to him when we told him they'd sell. Viva la Monster!
Finnster
KillaHurtz
Finnster's Avatar
02.15.2010, 04:43 PM
Will it fit under the top brace tho? Not so worried about the bottom as it can be managed. That will be the show stopper. If Mike knows, what is the max spur size possible under the top brace?
If everything fits under, even just a set of Savage crossbraces would be all that's needed to mount this inside the TVPs.
I know its for M3, but what concerns me is the holes and recesses cut for the M3s, and may not be big enuf for M4s. At worst I suppose you have extra long M4 screws (and washers if needed) and go all the way to the inside of the mount. I had to dremmel my Kershaw Designs mount to get the M4s thru. It can be done, but its a pita and, like you, hope not not have to hack up such a nice RCM piece.
02.15.2010, 05:07 PM
52t will fit the top, it did in my old one and the new one has even more clearance.
You're kind of stuck on the m3 hardware. Perhaps an adapter plate? I'd like to see this issue resolved too as I am going to use a 1521 in my LST with this mount. I'm glad you brought it up
Finnster
KillaHurtz
Finnster's Avatar
02.15.2010, 05:23 PM
Sweetness. I can make the M4 hardware work. The clearance on the spurs had me worried from what was said, and there isn't any specs listed.
Can someone measure the distance from F and R braces when they get a chance please? IE, what is the distance the drill holes need to be? Or just attach a PDF of the drill template.
I'll have to get a little fund going to get one of these as the weather gets warmer.
Mikak
AKA: MJBE
02.17.2010, 06:30 PM
has anyone mounted one to a truck ? if you have post pics please. im trying to figure out how to mount them to a G3.
  Send a message via Yahoo to Mikak Send a message via MSN to Mikak
feistyacorn
feistyacorn's Avatar
02.17.2010, 06:39 PM
I just got mine last night and I will post pics once I figure out what to do. Has anyone found out what we are going to do for drive shafts? I contacted Mike but haven't heard anything for a week now. I don't think he likes me. Where did he disappear to?
Rivermaxx
02.17.2010, 09:21 PM
I think we are going to have to make a small lower skid that screws to the bottom of the chassis with the existing counter sunk screws. The hole in the bottom of the g3 doesnt help much for mounting the cd mount.
