Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
thzero
02.17.2010, 05:40 PM
Mmms.. you have a point there. Truggies are running a 4.3 reduction.
Originally Posted by Finnster View Post
The other problem I saw when I was looking at my Sav conversion was loosing the gear reduction of the tranny when going to a CD. The tranny has a ~2.2:1 reduction.
The bulletproof diffs are lower GR than the originals as well. 3.22 vs 3.42. With only a 3.22 reduction and no tranny, you need a big ass spur and small pinion to make a decent FDR. Of course, big ass spurs want to hang low out the bottom....
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.17.2010, 05:43 PM
Agree, did not compute in my pathetic brain until quoted.
Edit, Pardon me for not thinking this through prior to posting.
What about a 1527/1500KV motor on say 8s with a CD, the gearing will still be ugly high for the application ?
nitrostarter
nitrostarter's Avatar
02.17.2010, 06:27 PM
Most definitely. 44,400 rpm's and a fast FDR sounds like a high speed running rig. The standard flux f/r diff ratio is 3.3 and the bulletproof is 3.22 so they are relatively high speed compared to Truggy(4.3).
In order to run a CD would would need a lower KV motor or big spur/little pinions, which tend to wear out faster. Even on 6s with that motor, you would need about a 15/51 pinion spur combo and still push 50+ mph.
N. Rustler conversion
thzero
Mmms, you'd need a different pinion for the front and rear diff. Instead of a 13 tooth pinion, you'd want to use a 10 tooth pinion. This would give you the same gear ratio with a center diff as a truggy. Or if using the bulletproof diffs, you'd need to run a 7 tooth pinion instead of 9 which would give you a 4.14 ratio so you'd need like a 47 to 52 tooth spur and a 11 or 15 or so pinion.
Basically you'd need someone to machine a replacement for parts #86031 or #102246. Or try and replace the diffs with something else. What is the ratio of the Cen diffs?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.17.2010, 07:05 PM
Uuug, more comlpications
Maybe getting the Flux trans to work is best then.
Thank you for the explinations on the gearing aspect gentlemen.
