02.19.2010, 02:40 AM
Originally Posted by jhautz
You need a new avatar now... A paint can with a circle/slash over it. LOL
That's not a bad idea! Maybe I'll cook something up this weekend if I remember.
Originally Posted by nitrostarter
I hear ya. Thats my new motto as well. It's depresing to spend time and money painting and then tear it up. Its fun yes but I give up on painting.
This Ten-T is hyping up to be a nice conversion! Might be the new craze. But I too am surprised that Losi didn't release an electric version. With the craze of electrics and conversions now-a-days I'm actually shocked they didnt. I'm surprised they don't offer an electric truggy either... I sure hope they don't jump the bandwagon soon! I hope Mike can get yet another great product out to this community!
They probably do have something in the works; they just got this out first. Then again, from what I hear about Losi's BL systems, maybe they are waiting until they come up with a better system...
Originally Posted by hootie7159
dammit!! sure wish i didn't just sell those terra pins i had...  woulda made the ten-t look like a wheely king on steroids...lol
If you do decide to go with 17mm b/truggy wheels, you will need the 14mm to 17mm hex adaptors, which I think Mike is gonna make as part of the kit. I know he's making some for me anyway.
02.19.2010, 08:10 AM
Originally Posted by BrianG
Probably not too bad really. The stock tires are close to the same diameter, but a little wider than buggy tires. So, the width might be a little off. You can get an idea from the pic posted earlier in this thread, but here it is again for your convenience:
Personally, I think 8th scale truggy tires would make it look like a MT, which might be ok for bashing since it will offer a bit more clearance.
As i can see if you mount 1/8 truggy tires, they will hit the body:( And it should be geared low
02.19.2010, 08:17 AM
If there is a way to retain the mechanical brakes, this would be the fastest SCT on the track!
Losi 8 Buggy + Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM, MGM, Xcelorin ESC's
Tekno Neu "square can" brushless motors
Polyquest - Neu - Flight Power LiPo's
02.19.2010, 09:33 AM
i dont think so, cause if you put the brushless motor where the stock nitro motor is, then you cant fit a battery (maybe 2200mah) Lol
im just gonna use the ESC / motor brake:) That will be harder on motor and esc, but keeps the weight down
02.19.2010, 10:56 AM
No, you put the motor on the other side. Also you can get away with a small brake servo and weight will be negligible.
Site Owner
02.19.2010, 01:52 PM
Mechanical brakes are not needed imo. A proper setup will perform as good with less complication - the center diff will bias the braking just as it does the acceleration. If nitro could brake the whole diff rather than each half of it, they likely wouldn't use mechanical brakes either. :)
02.19.2010, 06:35 PM
Heeeeeeey mike:D
Since you have the time to reply, then you must be finished? :D Or am i dreaming?
Site Owner
02.19.2010, 08:24 PM
Yes, you are dreaming - I occasionally come up from the work dungeon to eat, sleep and check the forums, though. If I only came on the net when all my planned projects were done, I would never be around! That said, this is a cool little truck and it won't be long before the conversion kit is done. :)
02.19.2010, 08:26 PM
lol, as long as your definition of "soon" isn't close to the definition Castle used when they released the MMM.
02.19.2010, 08:29 PM
Well thats fair it is 1:26AM atm, so i should be dreaming...
When you say "Won't be long" Thats long for me XD
Take your time:) Its still bloody snowing in Denmark, so i cant really go bashing anyway:(
02.20.2010, 03:44 PM
I recieved mine Thursday and have already pulled the engine and electronics. Today I pulled the center diff and filled it with 5k. While I was at it I tried a Losi plastic 45 tooth spur but it does not fit. Wondering what the pitch of the spur really is, Mod 1 seems like it may work but it's not perfect, Mod .8 does not fit very well either. I don't have any 32 or 48 pitch gears to try, it's almost as if it's Mod .9, somewhere between 1 and .8.
Lol, just sold the radio for $180.00 in about fifteen minutes, now if I can get as lucky as BrianG on the engine the roller will be free.
n00b
02.21.2010, 05:19 AM
@ fg101c:
Originally Posted by briang
a shot showing the differences in pitch between mod1.0 and 32p/mod0.8:
i just did more playing around with the center diff spur. It measures exactly 44.44mm in diameter, and has 48 teeth. That does not match either mod1 nor 32p, but is somewhere in between. After doing a little calculation, the pitch is actually 28.578p, or mod 0.889. I knew it didn't look right.!both 32p and mod1 gears roll somewhat smoothly without skipping, but don't mesh perfectly.
Btw, the formula for finding the pitch is:
Pitch = (tooth_count+2) / (gear_diameter/25.4)
module = 25.4/pitch
so, losi decided to really do some weird stuff here with the gears. The easiest thing to do would be to convert to mod1 or 32p. But as i said, the diff has to be flipped around, which means the diff has to be raised to clear the chassis. To minimize the amount of height increase of the cd, a revo 40t spur could be used, which is 42mm in diameter. This knocks off 1mm from the radius of the stock spur, which means it will fit without raising the cd much. And the 40t spur with a 12t pinion, along with the 4.41" tires, creates a speed of 30mph@30k rpm. Yeah, a little slow for some, but increasing the pinion to 14t creates a 35mph speed while not gearing up too high. And/or get a motor/voltage combo to get 35k rpm and the 12t pinion gets you 35mph. 14t would get you a little over 40mph.
Mugen MBX6Te RCM + Mugen MBX6e RCM + Savage Flux XL FLM + MERV all with Spectrum DX3S || WTS& WTB
02.21.2010, 10:57 PM
Happy now? See new avatar (wait a bit...)
02.22.2010, 12:33 AM
LOL Classic!
to make it...
or break it...
Silent...But Deadly
02.22.2010, 12:16 PM
Hahah brian XD
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
