hyper9e
silly nitros....
hyper9e's Avatar
02.24.2010, 10:25 PM
I personally wound not get a Feigao motor period. Don't skip on your power system! If you do, you will end up spending much more in the end as opposed to buying it right once. For a 6s set up, go w/a Tekin TT2345 1400kv buggy motor. Much better choice.
As far as which pinions and gearing...this is your best friend...http://www.scriptasylum.com/rc_speed/index.html
RCM has plenty of 5mm bore pinions to choose from in the store as well as the Tekin motor I listed above
As far as wheel tire combos...1/8 buggy wheels- badland tires for all around bashing are superb. ( They are not so good on a track ) Knockoffs to the badlands can be had pre-mounted cheaply on e-bay. I have a knock off set and the work flawlessly
+1
"Every time I hear/see a nitro motor, I actually get angry" -BrianG
