Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Krawlin
Got brushless?
Krawlin's Avatar
02.27.2010, 12:49 AM
PICTURES!!!
And don't mind the welds on the one that is already welded together, I still have ALOT of finish work to do, and I had to do a bunch of smaller tack welds because my attempt at a bead made a globby mess (I think I had my voltage and wire speed up too high for small stuff like this, and it's welded using MIG. When I weld the others I will lower the settings alot and see how they turn out with legitimate weld beads).
Anyway, all the parts came out great, the CNC plasma cutter is amazing. Very little slag, only a couple of the motor plates had real stuck on slag, everything else just came right off with the wire wheel. I still have to drill holes in everything though, if I left the holes in the CAD drawing for the CNC plasma cutter to cut out, it would have made them way too big since they have like a 1/12'' cutting width.
Monster GT Conversion
rawfuls
roofles.
rawfuls's Avatar
02.27.2010, 12:51 AM
What's the weight on that fatty?
Krawlin
Got brushless?
Krawlin's Avatar
02.27.2010, 12:56 AM
It weighs 6.75 ounces (192 grams). Not too bad considering it's 3/16'' (4.5mm) steel. Possibly overkill, but I didn't want it to bend.
