squeeforever
squeeforever's Avatar
03.02.2010, 03:50 AM
Well, that the switch layout. If you're asking how to hook the LED/resistor up to the switch:
1: Supply voltage goes to the NO terminal.
2: One end of resistor goes to C.
3: Other end of resistor goes to LED anode
4: Cathode goes to ppower supply ground.
5: If you are hooking up other things to the switch, hook the circuit to the C terminal.
I think I get it.
Basically I just need a on off switch for my interior LEDs. Its pretty much directly powered. I just cut the wires that go to the 12v plug and use the positive to go in to the switch then the switch goes to the + of the control box for the LEDs, then the - of the LED control box goes to the - of the 12v plug.
Edit: Yup, I'm sure.
