03.05.2010, 12:49 PM
What did you have your delta peak set to? I set mine to the lowest value on my charger (3mV per cell IIRC) and it works fine.
The charger I am designing uses thermal peak detection so once the cell gets to X*F, it shuts off. I feel this is a better method to detect when full charge is reached without relying on an unknown delta peak value that works well with these cells.
