If you chose to upgrade to the field programmer for $10.00, we should be shipping those out shortly. If you can PM me your info, I can look it up and give you an update. If you only asked for the standard free link, we are currently working on some and they should be available soon as well.
Thomas Porfert
Castle Tech Support
Thats great, I will have to due that when my next mmp gets here.
I just had another go at it again and was able to recreate the problem. The only thing I can suggest is to slow down. I think the Programmer is missing the click, so try waiting just a second after changing the setting, then click it again to go to the next setting. When I slowed down I couldn't recreate the problem, but when I did it quickly like you did in the video, it recreated the problem every time.
Thomas Porfert
Castle Tech Support
Reason: Misspelled Frost's name, there's no Y at the end :P
Thomas: Thank you for the advice. Somehow it doesn't happen to the other parameters on Field Link, but only the Motor Type and Motor Timing parameters. Nevertheless, it is a great product, and I like it very much. I find it very useful at the racing track
