mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
03.10.2010, 12:07 AM
Can I bother someone into measuring the top chassis plate LOSB2287 from front to back and side to side? Thanks.
No brain, no headaches.
JThiessen
JThiessen's Avatar
03.10.2010, 10:53 AM
Which one is that - LST, LST2, or XXL? I have a pdf drawing of the LST top plate (Attached file), and will have one of the XXL shortly.
Print it on a 11x17 paper and it should be full scale.
mistercrash
Guelph, Canada, eh!
03.10.2010, 01:10 PM
Sorry I should have been clearer, I was thinking of the XXL top chassis plate. Thank you for the pdf file.
JThiessen
JThiessen's Avatar
03.10.2010, 02:21 PM
So I'll be getting my XXL chassis sometime in the next week, and should have the dim's on it late next week for ya.
mistercrash
Guelph, Canada, eh!
03.11.2010, 12:48 AM
Thanks a bunch.
JThiessen
JThiessen's Avatar
03.13.2010, 08:00 PM
My pile of new parts is growing into a daunting mountain of goodies - and I don't think I am quite done ordering things yet. Seems these trucks aren't quite popular enough that you can get everything you need from one vendor. So far I've used Mike, A-Main, OverdriveRC, StormerHobbies...and Ebay.
I got the Slipperential (50T, Hardened endcaps) assembled and installed in the Muggy today. Had to open up the slot in the chassis by almost double the width, and about .3" length wise. You also have to clear for the slipper.
I had a heck of a time with the teflon washer - just a hair too small. I put a small chamfer on the cup and finally got it forced on, but a piece of the teflon pushed back out. Used a screw driver and the end of a socket wrench to basically mold it back in. Another note on the slipperential - clean those screws before putting your threadlock on. They are still oiled from the manufacture, and your threadlock will do little with that oil on them.
Also got Mikes large batt tray installed - fit great on the Muggy, and still left room for the MMM right behind it. I do have to say, my 5S Neu's are a very snug fit in the tray.
Was planning on putting the 1515 2.5D in it, but as I was removing it from the 8T, I discovered a wire connection that apparently had been having some serious shorting. All along I thought I had blown a diff in the truck - it started hesitating on me periodically right after I jumped it off a 20 ft wall into some soft sand. I only ran it for another 20 minutes after this occured, and havent bothered taking it apart yet. I'll have to pull the connector off and solder on a new one.
So out came the brand new 1520....
I'm still concerned about bending Mikes motor mount with this thing. Just light pressure with my hand I could see movement in the mount. BUT....I still have to fab and install a top plate for the diff mounts - so that might help with that.
Just have to mount the reciever, and make some servo mounts (the Muggy didn't have any of the plastic screw pieces with it). Hopefully I can put something together out of the extra's off the LST.
I'll get some pics up later......
MC...I got the XXL chassis yesterday. It is quite a bit bigger - how accurate of a measurement do you need? If you just want a tape measure number, I can get that for you today/tomorrow.
JThiessen
JThiessen's Avatar
03.17.2010, 12:43 AM
So I ahvent got any new pics...too much to do. But I did get the XXL chassis dimensioned out. Here are the PDF's of the upper and lower chassis.
