George16
Supermaxx
George16's Avatar
03.16.2010, 04:03 AM
A Kyosho plastic spur will fit. I don't understand how you manage to shred pinions with steel spur. I had been running my ST RR with a lightened 46T Kyosho steel spur with an RCM 15T pinion since Feb last year and the teeth still looks new. Are you sure the mesh is okay? You have to put a little of play on the gear teeth when you're setting up the mesh.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
