Nick
COOKIES!
Nick's Avatar
03.12.2010, 09:05 AM
I know the diameter is bigger on the 1717 than the 1515s but are the mounting holes the same?
~ Nick.
03.13.2010, 07:09 PM
25mm hole spacing & M4 holes/screws.
Unless Im trippin' again.
V0RT3X
Muggy love
V0RT3X's Avatar
03.18.2010, 01:34 PM
Are the listed motor lengths on the CC site with or without the shaft?
rotary rocket
No Pistons
rotary rocket's Avatar
03.18.2010, 01:48 PM
Is there a new ETA on the 2025? TIA.
That's a 1512, a 1717, and a 2025 motor side-by-side.
03.18.2010, 07:40 PM
Without- just checked my 1518 and its 83.5mm as listed on the chart/site.
Thomas Porfert
Thomas Porfert's Avatar
03.19.2010, 12:06 AM
This is true for all motors listed on our site. I'll ask our webmaster to add that to our motor listings to avoid future confusion; that should have already been up there. My bad.
For those of you needing a 5mm shaft rotor, please e-mail me your information and I'll make sure we get you on the list. It may come with a prepaid mailer to send the 6mm version back, but that has not been decided yet. I'll check with our international liaison and see if there's an updated ETA.
My e-mail address is: Thomas (at) castlecreations (dot) com.
Thomas Porfert
Castle Tech Support
Last edited by Thomas Porfert; 03.19.2010 at 05:55 PM. Reason: Forgot to put e-mail address.
RuthlessLST
03.19.2010, 01:45 PM
SWEET!! I almost have a set of tires worn down from pushing my truck back and forth on the floor making vroom vroom noises.
V0RT3X
Muggy love
V0RT3X's Avatar
03.19.2010, 05:19 PM
And how long is the shaft on the 1520/1717? Around 20mm? But I can still cut it short if needed.
Thomas Porfert
03.19.2010, 06:09 PM
They are 18-21mm, 20mm on average.
Same size bolt pattern, ~ 25.4mm center hole to center hole; 3mm screws on both.
That means you could fit a 1717 motor to the mini E-Revo tenbol mount. A motor that weighs more than the car? I don't see a problem with that! :)
Thomas Porfert
Castle Tech Support
nitrostarter
nitrostarter's Avatar
03.19.2010, 06:39 PM
Thomas Porfert
Castle Tech Support
Would be cool, but you couldn't gear it high enough to take advantage of the torque it makes. You you need an output multiplier...
N. Rustler conversion
V0RT3X
Muggy love
V0RT3X's Avatar
03.20.2010, 04:09 AM
Thomas Porfert
Castle Tech Support
Aren't the screws on the 1717 4mm?
NickRummy
NickRummy's Avatar
03.20.2010, 07:47 AM
They are 4mm on mine. Thought they were 3mm too like listed in the specs but they arent. Atl least the older ones arent.
Thomas Porfert
03.20.2010, 12:54 PM
I'll have to double check a production motor on Monday. I was measuring a prototype motor in engineering, so it may have changed before it hit production. I was thinking 3mm seemed a bit small for that size motor, but I'll verify on Monday; sorry for the confusion.
Thomas Porfert
Castle Tech Support
V0RT3X
Muggy love
V0RT3X's Avatar
03.20.2010, 01:07 PM
How does the 1520 compare to the 1717 in terms of torque? It's a bit longer, does that mean more torque? Or is that a matter of diameter?
I'm gonna dump the 2200 out of the Flux and get a 1520, just enough room to mount it and the diameter is the same. I'd have to make a new mount for the 1717.
Will it suck on 4S?
nuz69
nuz69's Avatar
04.02.2010, 07:05 PM
It will suck on 4S if you dont gear up a lot. The 1717 rotor is larger, therefore magnetic forces are stronger, and it has more torque than the 1520, but it draws a little more amp than the 1520 (less runtimes).
