My 1520 is in my Muggy
Slipperential in the middle, 50K, and slipper tight.
5S Neu pack, MMM (dont know what settings I have it on right now)
50/18 gearing
I have only run it up and down the street a couple time so far, but its got plenty of power. Does NOT lift the front wheels off the ground, little slip on take off (dry pavement). But it does seem to run real cool so far.
Originally Posted by magman
1. I did put small washers between center diff mounts and chassis to raise everything up a bit for more clearance
2. I have the motor timing to 0
3. IMO the 1717 is too big for a truggy, heck the 1520 is a bit on the large size, but, I wanted a motor that I would not have to worry about. I was running a 1515 ccneu before and that was just fine as well
Hey guys... can you post photos of your 1520 setups... it will help to illustrate a 'clearer' picture on how you have modded your trucks facilitate this monster....
Thanks, I went and pulled the settings. 0% punch, 60% brake, 13 for timing. It weighed in around 12lb RTR and 120k CD fluid. 13 for timing sounds a little on the hot side, I dropped it down to 9 to try next time.
Nice... can you make comparisons with temps on different timing setups? Oh.. and also run times...
Kcaz25,
I am pretty sure they are not taped, I got them used pre-mounted. I do have some rubber bands on the outside I guess that might help a little. I plan on doing a fishing line wrap soon to them.
Thanks Nuz69,
I can drop the timing to 4 and re-try.
