scarletboa
scarletboa's Avatar
03.24.2010, 12:16 AM
i put a associated plastic center diff gear on the truggy and it is very quiet. gear wear is no longer a problem, but there are 2 new problems.
i can't tighten the 4 diff screws without the plastic gear warping
the center diff now leaks all its fluid within 5 minutes of driving (probably from not being able to tighten the gear enough. yes, i did remember to transfer the o-ring and use the gasket that is included with the gear.)
