03.24.2010, 11:04 AM
It also matters if the coil configuration is Delta (also called "D" or "triangle") or Wye (also called "Y","star", or "asterisk") wound. Delta wants low timing, while Wye can benefit from higher timing. The Castle motors are all "Y" wound IIRC.
