Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
nitrostarter
nitrostarter's Avatar
03.25.2010, 10:26 PM
Well the higher voltage and lower kv is a preferred setup. You can run lower mah packs like the 3300mah to get the weight lower. Power and acceleration should all be roughly the same for track usage.
I do know the Tekin motors aren't as notchy either.
You don't have to run the RX8 unless you want to take advantage of the sensored running. Sensored is pretty nice on slow take offs and corner speeds. I'm not totally convinced it will improve anything since the RX8 shifts to sensorless while the rpms increase.
N. Rustler conversion
georgec
georgec's Avatar
03.26.2010, 06:09 AM
Thanks, I'm trying to come up with ammo to present to the track owners witch have adopted the ROAR 4s rule, but I believe can be swayed if I can prove to them that the only advantage to 6s is efficiency! I'm also on the hunt for a lower kv motor, and so far I have looked at the Tekin 1400kv that is priced at around $150.00 and the CC 1600kv priced at well over $200.00 Last night I came across another motor that Castle is carrying it's their NEU/MR 036/060/1300V5 priced at $119.00 makes it the most affordable. But if I'm reading the #s correctly this motor is only 36mm x 60mm and that seems small for racing. Has anyone here had any experience with these?
