ReV:-O
RC-Monster Carbon Fibre
03.26.2010, 05:23 PM
looks like im gonna be doing this the hard way! time to break out the 80 watt iron
georgec
georgec's Avatar
03.26.2010, 05:38 PM
Just be very careful not to short out the wires! Lipos can't take even the slightest short. Your best bet is to cut strip and solider one wire at a time.
ReV:-O
03.26.2010, 07:19 PM
yeah lol when I was soldering my neuenergy lipo i shorted it out twice, i accidently let the two ends touch, and then later they shorted out over the metal pliers! they seem to still work ok 5 months later...
thanks for those tips, i'll keep them in mind. When you say flux, do you mean solder? I'm a bit confused.
cheers
josh9mille
josh9mille's Avatar
03.26.2010, 08:21 PM
I usually use a rubber band to hold one wire back around the pack so its impossible for them to touch while soldering.
scarletboa
scarletboa's Avatar
03.26.2010, 06:15 PM
when i had to solder deans plugs on my 4 turnigy packs with 8awg wires, i got a few tips that really helped.
1. i used a 80w soldering iron
2. extra flux on the wires makes the solder flow so much better
3. helping hands (or at least some locking pliers)
4. a tiny bit of flux melted onto the solder surface of the deans plug helps too
the flux makes a huuuuge difference. all you have to do melt some non-spill-able flux onto the wire, load a ton of solder onto the tip of your iron and touch the iron to the wire. the solder will flow on very nicely. you may need to load the iron a couple tires if you have a small tip. i used a large chisel tip and it worked perfectly.
