steveo
03.26.2010, 08:39 PM
remember the ampacity will be smaller unless you use a higher C rating than the 5000mah you have- i dont think your formula will work out quite like you want
if you used a 6s battery with correct rpm motor geared for the same speed then you might be able to use the smaller mah battery making your system more efficient
simplechamp
simplechamp's Avatar
03.26.2010, 08:55 PM
But the lighter vehicle should draw less current. So yes, a smaller capacity battery wouldn't be able to produce as much current, but it wouldn't need to produce as much since the lighter vehicle presents a lower load.
I don't think the 25% lighter = 25% less current is quite right though either.
