nitrostarter
nitrostarter's Avatar
03.29.2010, 10:16 PM
Well the only thing you really did was increase your spur gear. Not sure why you ant to do this? Maybe less wear on the gears due to larger teeth counts or more surface area.
Buggies are setup with buggy diffs and a low to mid forty tooth pinion and 3.30 ratio diffs to account fr the 4.5" tires used.
Now if want to swap in buggy diffs in the truggy, you could really gear high and make a dangerously fast truggy.
N. Rustler conversion
