moogenite
Let non survive!
moogenite's Avatar
03.30.2010, 03:55 AM
Dusty conditions?
is it only the outside bearing? no problem on the diffs?
Because i used blow much diff bearings, it was very dusty where i drove then.
Are your wheels out of wack? unbalanced wheels may cause failure.
Bearing failures.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Bearing failures. - 03.30.2010, 04:28 AM
Bearing failures are usually caused by one of three reasons.
1) poor intallation
2) no lubrication
3) dirt intrusion, or overloading
Overloading could be from unbalanced equipment, hot equipment to close, or wrong bearing for the job.
What type of bearings are you using?
SUPERMAXX YOUR LIFE.
Just wrong.
JERRY2KONE
JERRY2KONE's Avatar
Just wrong. - 03.30.2010, 04:31 AM
And consider yourself lucky, this guy has some serious rear end issues:
Your a sick puppy James. That is just wrong. What kind of porn are you looking at in your spare time? Pick yourself up a Playboy or a Hustler.
