itbvolks
04.06.2010, 10:45 PM
Double.
itbvolks
04.06.2010, 10:53 PM
Sounds like the 1520 would be a good fit overall for the truggy. It basically means I'd be down roughly 1850rpm with the reduction in KV but I wouldn't think that would be too tough to overcome with gearing changes and if it'll pull the bigger gear without overheating (which it sounds like it will with ease), that would be ideal....
Certainly seems like the motor makes significant steam!!!
bruce750i
bruce750i's Avatar
04.07.2010, 11:36 AM
I went out for a run again after tying fishing line around the savage tires so no tire balloon effect for this test. I tried 4* of timing and ran it for 15min. I burned up 5ah at 23v(6s) in 15min with 16/54 in a 12lb. rc8t. 125*F motor temp. Something seamed a lot more tame about it. I think it was the lack of the tire balloon effect. I will have to retest with a higher timing setting.
Jahay
04.07.2010, 12:37 PM
do you think this motor would be suited for a savage flux geared at 25tpinion/44t spur and 39t High speed idler? That should bring me to a 60mph top speed on 6s right?
bruce750i
bruce750i's Avatar
04.07.2010, 12:43 PM
This might help with finding mphs check it out. http://www.scriptasylum.com/rc_speed/index.html
Jahay
04.07.2010, 02:00 PM
with high gearing, would temps stay in check? Has anyone run similar high gearing on their truck without temp problems?
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
04.07.2010, 02:09 PM
What are your objectives with that setup? just speed runs or bashing?... the truck's weight and tyre sizes should be factored in also...
did you try your number in the calculator? If you post the results from the calculator here, we can look at it a little closer and
see how best to approach your setup.
Alien
bdebde
That's All Folks!
bdebde's Avatar
04.07.2010, 03:23 PM
A 12lb truggy?...That thing needs to go on a diet!
Jahay
04.07.2010, 03:55 PM
Alien, i only bash but i have plenty of space to run and love my high speed runs... But i dont do repeated high speed runs like some do. My truck is around 13lbs and im running strapped HPI dirt claw tires on SPI Rims.
these are the results i got from the speed calc
Differential Ratio: 3.3076923076923075
Transmission Ratio: 2.215277777777778
Other Ratio: 1
Spur Tooth Count: 44
Pinion Tooth Count: 25
Total Voltage: 22.2
Motor KV: 1800
Tire Diameter (inches): 5.91
Tire Ballooning (inches): 0.5
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 1.76 : 1
Total Ratio: 12.89632 : 1
Tire Circumference (inches): 21.71 inches (551.39 mm)
Rollout: 1.68:1
Total Motor Speed: 39960 RPM
Vehicle Speed: 63.7 mph (102.32 km/h)
Effective KV Value: 1800
KT constant: 0.75 oz-in/A
As you can see on a 6s running 44/25 and accounting for tire ballooning at 0.5" i can hit 63mph supposedly... This setup doesnt include the 39t Idler which would probably give me up to 10mph more.
If i really am capable of these speeds then i would def gear down as i would never reach those speeds anyway.
ANGRY-ALIEN
04.07.2010, 05:01 PM
hmmm... Interesting... but i'm a little confused... Do you want to run 1520 or a 1518? the 1520's KV is 1600 (you have 1800 which is the 1518's KV)...
I am pretty sure the 1520 can push that truck to the 60s, but if you are going to bash with it geared that high (accelerating hard and braking hard), the motor
might start getting warm a little faster... I have geared my truck for the high 40's to 50's and the motor handle it well... but I don't think during bashing
I have ever gone past the lower 40's... So now I am geared for the high 30's and the motor seems to like it temp wise and the acceleration never gets old.
Your setup with some changes:
Other Ratio: 1
Total Voltage: 25 <------------- 6s on peak charge
Motor KV: 1600 <-------------- 1520
Tire Ballooning (inches): .5
Rollout: 1.68:1
Total Motor Speed: 40000 RPM
Vehicle Speed: 63.76 mph (102.42 km/h)
Effective KV Value: 1600
KT constant: 0.85 oz-in/A
I recommend you gear down for bashing (it should make your Batts happier too):
Other Ratio: 1
Pinion Tooth Count: 18
Total Voltage: 25
Motor KV: 1600
Spur/Pinion Ratio: 2.44 : 1
Total Ratio: 17.91156 : 1
Rollout: 1.21:1
Vehicle Speed: 45.91 mph (73.74 km/h)
Other Ratio: 1
Pinion Tooth Count: 16
Total Voltage: 25
Motor KV: 1600
Spur/Pinion Ratio: 2.75 : 1
Total Ratio: 20.15051 : 1
Rollout: 1.08:1
Vehicle Speed: 40.81 mph (65.55 km/h)
Jahay
04.07.2010, 06:39 PM
although i think the torque of the 1520 would be ideal... i think the 1518 would be more suitable for me. My truck isnt too overweight compared to other savages...
I think i would run an assortment of pinions depending on what surface or what sort of running i would be doing that day (asphalt, grass, dirt, or pure jumping) I am just making sure that if i do run on asphalt and run high gearing, that i do not cause any damage to my motor or esc. I would probably no run 25T most of the time... But i would like the assurance that i could if i want to and get away with it.
nuz69
nuz69's Avatar
04.07.2010, 06:50 PM
Hello Jahay.
Anyway, the 1520 would be the best choice for your application, because it can handle more power than the 1518 and had always an higher efficiency.
Where the 1518 works good, the 1520 works just better in truck and truggy. You have all to gain by choosing this one, and the cons are insignificants : +30gramms and maybe +10-15$ with the insurance to keep the motor cold even by pushing it hard.
The 1518 should be the right choice for buggies geared in 5 or 6S for high speed tracks but it just can't match with a torque monster 1520 in heavier vehicle like truck or truggy/muggy...
Jahay
04.07.2010, 08:20 PM
Thanks nuz for your opinion... The difference in price between the two motors really isnt a factor when you are spending this sort of cash. neither is the weight i guess. But i guess i am worried that i will not be able to gear high enough to reach my desired speeds. but according to this gearing, it looks like i can just about considering the high speed idler gear will be installed.
Differential Ratio: 3.2222222222222223
Other Ratio: 1 + high speed idler gear should add around 8-10mph
Spur Tooth Count: 44 stock spur
Pinion Tooth Count: 25 largest pinion
Total Voltage: 22.2 ideal average voltage
Motor KV: 1600 neu 1520
Tire Diameter (inches): 5.5
Tire Ballooning (inches): 0.5 Hpi dirt claws on spi rims
Motor Current Draw: 0 not sure how many amps the motor would draw on stated gearing. would esc overheat????
Total Ratio: 12.56309 : 1
Tire Circumference (inches): 20.42 inches (518.68 mm)
Rollout: 1.63:1
Total Motor Speed: 35520 RPM
Vehicle Speed: 54.67 mph (87.82 km/h)
if this speed calc is accurate then i would get the 1520 immediately. i need a motor asap... starting to get savage withdraw symptoms haha.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.07.2010, 08:38 PM
IMO, the 1518 is waaay more motor than a buggy needs and plenty for all but the porkiest trucks. The 1520 is plain overkill unless you have a 15lb truck with big aluminum rims or something.
Jahay -an idler gear doesn't add any speed or take any away - it is simply there to create space(usually to allow proper gear mesh with a larger diameter motor or small spur gear) and it reverses the direction or rotation(as far as the gear ratio goes...it is "idle"). :)
Jahay
04.07.2010, 08:48 PM
i thought 1520 would be completely un necessary, considering i thought my torq2200 was pretty adequate already.
So i may just get the 1518 and can also gear a couple of teeth lower on the pinion considering it spins a little faster than the 1520.
Nice1 Mike. I think they are in stock in the rc monster store...
