Thread Tools Rating: Thread Rating: 58 votes, 5.00 average. Display Modes
J1A1H XXL Torque Monster Buildup........
Jahay
J1A1H XXL Torque Monster Buildup........ - 04.27.2010, 07:36 AM
[b]Ok, my build is coming together now... Ive decided to list everything i have bought for this truck so i remember exactly how much effort i have spent on this truck.
The 1 picture i have when it arrived at my door.
by the way this : ? = a british pound sign
Complete List So Far:
Second Hand Savage Flux ?500.00
It came with 6 Lipo Batteries 4x2s & 2x3s
Spare tranny
Proline Dirt Bonz Wheels
Fibre Glass Shell in white
Ansmann GHZ Trans and Rx
Cheapo Charger
Power supply ?35
Motor & Power
HYPERION G3VX 3s/6500mah/35c lipos ?140
Neu Castle Creations 1520 1600kv Motor ?120
Chassis Kit
GCM DB-17 Chassis Kit C$96
GCM Batt tray C$24
GCM Skid Plate C$23
GCM servo mounts x2 C$15
Rims & Tires
SPI Basher Wheels $115
Dirt Claws Tires ?50
Proline tire inserts ?10
Steering & Handling
HPI RSC suspension conversion kit ?85
"Good Fake" aluminium BIg bores from HK (only for road use) ?35
HPI XL Axle Extenders $15
Shock Springs (white) X8 $15.56
Ace DS 1015 Servo ?60
Ansmann alu servo horn ?10
HPI front and rear sway bar kit ?25
Aluminium steering tie rod ends ?11
Titanium turn buckles ?15
GPM Steering Assembly ?13
Shock Socks
Tranny, Gearing & Mechanical Brakes
Bullet Proof Diffs x2 $50
HPI HD 18-23t Drive Gear $11
HPI 39t high speed idler gear ?25
HPI Light weight idler gear 29t ?7
HPI Light weight drive gear 32t ?7
17t pinion (Bashing & Jumps) ?11
21t pinion (Grass and dirt surface) ?11
25t pinion (Road use) ?11
Ofna throttle mod ?8
HPI Dual Fibre glass brake & Discs, piston, cam & hex ?15
Bodies & Wing
White stock size fibreglass body Came with flux
Custom Silver Fibre glass body ?75
Proline DesertRat body for slayer ?30
Monster Energy Decals ?10
PRC carbon wing mount ?25
Hot bodies wing mount & screws ?10
Traxxas carbon revo wing ?10
Extra Stock parts & EXTRA BITS
Castle Link USB ?13
Servo Y harness ?2.39
Spider Gears x2 $6.70
Steering Bearings $8.45
Servo Saver $2.22
Diff gaskets $2.25
velcro straps x6 ?10
Corrosion X for waterproofing ?20
Diff Oil 30k & 50k ?5
Car Stand ?5
Adjustable Upper Arms ?6
Savage X Arms ?12
Shock oil 35wt x2 ?2.75
Green Slime ?3.50
Traxxas ESC mounting Plate ?3.50
Alloy chassis bulk supports ?6.00
HPI Gold Washers and nuts ?9.00
Re enforced strapping tape for tires ?2.00
Extra nuts and bolts for HPI ?15
Rush Battery box ?7.65
HPI Front and rear skid plates ?6.35
8x wheel bearings ?5
Extra suspension screws ?5
Shrink Tubing ?3
Fuel tubing 1m ?1.50
Battery Foam ?2
As the parts arrived i got very excited... took some pics and here they are before they were fitted....
Rims, Tires & Inserts
Comparison Between stock inserts and proline
Tire Weight Comparisons
Strapping my tires
Sway Bar kit
RSC Goodies
Stock fibreglass body vs XL Fibre glass body
