Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.28.2010, 06:04 PM
Finished up all the loose ends and fine details and threw in a 5s 5K pack, did a systems check and applied throttle and next to nothing ? I was like WTF ?
After a quick check w/a volt meter I discovered a discharged pack, I have no other 5s lipos to fit this bat tray without adding a bunch of padding and by the time it finishes charging it'll be dark. So to hell w/it.
So I will test Thursday and capture some video if someone is around to hold a camera.
4mm shock bolts
Motors sealed via ShoeGoo and aluminum tape
Trusty Hyperion Duo getting R done (What a PITA to learn to use this charger, but wow what a kick ass charger !)
