George16
Supermaxx
George16's Avatar
04.29.2010, 02:24 AM
You're motor is fine. I asked the same question when I got my brand new motor last year. Castle said it's okay.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
nuz69
nuz69's Avatar
04.29.2010, 05:24 AM
Same here, in my 1520 and 1515, i can push the rotor in the motor, and then the rotor comes back with magnet force on the front bearing. I always wondered if it don't apply too much strains ont the front bearing, but all seems OK.
Dont forget to glue your bearings ! My front bearing was unglued and moving in the front bell, the are glued stock.
andreazinno
04.29.2010, 07:09 AM
Yes, I've glued the front, and this evening I'll check it to be sure it is firmly in place.
The stock bearing in the rear endbell wasn't glued (as far as I noticed), but in any case the bearing housing seems to be more tight that the front one, and in fact I've applied more pressure to insert the new bearing.
Bye, Andrea.
