05.02.2010, 11:16 PM
Make sure you balance those beadlocks, I have the same setup and they required quite a bit of weight to run smooth. Balancing tires is the best thing you can do to an rc. I can imagine the shocks, hingepins and bearings last longer.
Semi Pro
Semi Pro's Avatar
05.03.2010, 11:22 AM
i agree
my balanceing is alittle crude, i have a home made ballancer useing an 8mm rod with a 17mm hex adapter and a prop balancer. i use tamiya wheel balanceing putty.
i even weight matched the wheels before balanceing, im a racer first basher second, my buddy give me alot of shit about it. i always have to shim everything to perfection and weigh and balance everything before i run it lol
