Semi Pro
Semi Pro's Avatar
05.09.2010, 03:01 AM
quick update
i found this, looks like it should stop or limit the rear flex so that you arent brakeing bulkheads
jpoprock
"Don't act like you're not impressed."
jpoprock's Avatar
05.09.2010, 09:56 AM
quick update
Oh cool. I hadn't even thought of a roll bar. I wonder just how well that will work? I can't tell where it attaches. But yeah... if that is far enuff back, then it would work well!
J
ERBE: RCM 1/8 Hybrid Diffs, NEU 1515/2.5d/S MMM, 6S, Losi E-XXL CUSTOM, Neu1515 2.5d, MMM, 6s E-SLAYVO PRO ERevo Chassis w/ Pro 3.3 parts, NEU 1512, MMM, 4S.
  Send a message via Yahoo to jpoprock Send a message via AIM to jpoprock
Semi Pro
Semi Pro's Avatar
05.09.2010, 04:02 PM
J
it mounts to the rear post, like the turnbuckle mod and then to the transmission and the front radio box mount
jpoprock
jpoprock's Avatar
05.09.2010, 10:07 AM
quick update
Oh, one more thing... I was checking out my rear shock mount... and was wondering if I mount the tie rod end using one of the existing screws...just finding a longer one? Or if I am supposed to buy some kind of aftermarket shock mount that has a center screw hole?
I believe that the other tie rod end goes where rear body posts attach to the chassis, in the center.
That New Era Roll bar is only $16!
Semi Pro
Semi Pro's Avatar
05.09.2010, 04:00 PM
i used longer screws
that cage in the pictures is a new era cage
