nick8155
05.10.2010, 04:15 AM
Thanks,
Starting to understand a bit more now!
I will see what the runtime is like with a 12t pinion
nuz69
nuz69's Avatar
05.10.2010, 04:38 AM
Hum, keep in mind that higher voltage means higher RPM so higher losses in the motor bearings.
But for heavy trucks like truggys or MT, with the 2200kV, 5S with small gearing is the way to go, maybe on 6S the motor loses a lot of efficiency in the bearing...
A 1520 1Y on 6S should give you better efficiency anyway...
Brushlessboy, I would have a question : The efficiency at full throttle is best for the motor or ESC ? Or both ?
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.10.2010, 05:56 AM
I don't think you are grasping the whole point, or understanding what we are talking about...
When you go UP in voltage, you also go DOWN in gearing, resulting in the exact same RPM & Top-Speed as before...just with higher voltage.
So, going with higher voltage does NOT mean higher RPM since you are going with lower gearing at the same time. RPM remains the same with higher voltage and lower gearing, but the efficiency and run-time greatly increases.
-Chad
PM ME IF YOU HAVE THE BELOW:
nuz69
nuz69's Avatar
05.10.2010, 05:58 AM
No kidding
Read again what I wrote, I talked about MOTOR RPM, not transmission RPM
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
05.11.2010, 05:40 PM
if you are at half throttle the fets must turn on and off a lot to "limit" the voltage in laymans terms.
but at WOT the fets only need to shunt power to the 3 phases and that's it, no more in-between-phase-switching.
