Semi Pro
Semi Pro's Avatar
05.10.2010, 03:11 PM
Originally Posted by jpoprock View Post
Semi... Yes, that is the New Era cage... But on the traxxas thread, he made his own as well. I'm gonna get the roll bar instead of the full cage. I'm gonna try to measure to see how long of a buckle/rod will be needed to mount to the shock mount and tower. Might be unneeded if I get the roll bar?.
Also, when companies give you the length of a turnbuckle, is it from end to end including the ends, or is it just the length of the rod itself from end to end, not counting the end you screw on?
it wouldnt hirt to use both, normaly the turnbuckles are listed as the length without the end installed, but you can cut them down with a dremmel pretty easly (thats a tool every rc guy should have in his box and get good at useing).
i dont think the cage would be much help since it onlt ties the body monts together
