nitrostarter
nitrostarter's Avatar
05.13.2010, 08:05 PM
Ok so this charger ooks cool, thats about it. I tried 3 different lipos on it and none will charge. Everytime I try to start the charge, it say connection break. So I decided to try a lipo on Nimh mode, still the same so that should rule out the balance port being bad. I then check the outputs by reversing polarity. The charger noticed the reverse polarity as soon as I plugged it in. So there must be some programming issue with this controller.
I'm going to attempt to use Hobby King customer service and try to return this sucker....
N. Rustler conversion
pinkpanda3310
pinkpanda3310's Avatar
05.14.2010, 05:11 AM
That's too bad. I take it you'll be going to LHS for a Duo.
