05.14.2010, 09:31 PM
They are 4 spider gear in an alum cup with the steel reinforcing bits... I think they are the BP ones... The installer sadly decided to weld up the screws one of the diffs with green threadlock I think. I was unable to change the diff fluid - It seemed very light so threw it into the rear...
Wing mounts ok - Its what I had lying around so no harm done if it doesn't work...
I'll see what it looks like once chassis installed.
JThiessen
JThiessen's Avatar
05.14.2010, 10:48 PM
That may have been a factory diff - when I replaced mine I had to order complete new cups 'cause I couldn't get all the screws out with out stripping out the hex. But I seem to recall that mine were a steel cup...been a while, now.
Your gonna like this rig - don't let the handling fool you!
