Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
simplechamp
simplechamp's Avatar
05.18.2010, 07:08 AM
You can't really reduce the speed with the CastleLink. You can control the punch, and adjust the throttle curve, but that just changes the way it gets up to speed, the top speed will remain the same. The only way to truly reduce speed is to drop the gearing down, use a lower kv motor, or reduce the voltage. I guess you could adjust the endpoint on your radio, but the previously mentioned methods are much better choices.
