Zyoss32
Zyoss32's Avatar
05.19.2010, 09:45 AM
At work so every extra second i get i am checking thanks for responding so quickly
thinking of going this route:
Tekin rx8/1700kv combo out of stock on here
Hyperion G3 VX 5500 mah 5S 18.5V 35c/65c Lipo
RC monster conversion it is out of stock
my questions are gearing 16/46
is this mod 1 not sure and a newb question but i have an older hyperion charger the Eos dual 06 something how to power supply this thing i always charge with
cable connected to car battery any other options here again i am new to this
and need basic help thanks for all responses and advice
and what is best way to connect motor to ESC bullets deans direct soder?
Have a great RC day
Zyoss32
Zyoss32's Avatar
05.19.2010, 09:50 AM
ITBVOLKS great build i read entire thread and really that made my decision to go
with the mugen, I really do not understand the sliperential thing, keep the stock
or is this something as i progress and learn more i should learn now and do
does the RCM slip replace the the stock diff on the m spec or how does it convert thanks
Have a great RC day
Zyoss32
Zyoss32's Avatar
05.19.2010, 09:54 AM
Wallot yes you have an awesome set up as well, you guys are all much more
knowledgeable than me on this and when you say lightinged drive train what actually did you purchase to fit and from were did you get, aluminum vs steel
and etc. do you believe the BCE chassis is worth the investment for me I know
for you it is a no brainer you are very skilled driver and weight i take is the big
advantage it gives you over stock chassis i assume.
thanks again this will help me trememdously as i learn
Have a great RC day
