Pdelcast
Pdelcast's Avatar
05.19.2010, 04:28 PM
Hi Raydee--
What you need is a magnet wire stripper -- it's a machine with two rotating fiberglass wheels that mechanically strips the insulation off the wires.
They are expensive, but they are pretty common with motor repair companies. Look in your phone book to see if there is a motor or armature repair company near where you live, and give 'em a call. It's worth a shot.
You could also try a solder pot and some mechanical removal -- but it's hard to be sure you got all the insulation off...
Patrick del Castillo
President, Principle Engineer
