reno911
Smelly Nitro meet your maker!
reno911's Avatar
05.19.2010, 08:13 PM
My new set up is similar but I tossed the rx box and mounted my transponder in that spot, and the 2200 comes out a bit further. I also upped for the Traxxas aluminum motor bracket, and drilled two extra holes in the motor plate so the heavier motor has more support compared to just the two screws. If you want I could throw the rx box in the mail your way if you decide to go this route, I'm not using it.
