TexasSP
Something, anything, nothing
TexasSP's Avatar
05.20.2010, 09:10 AM
I would work on shimming the diffs, it can provide a world of difference. Another option is aluminum diff cases and cups. This will eliminate the flex that can cause problems as well, but again shimming is imperative.
Shimming takes some trial and error and the diffs always have to be shimmed on both sides to keep everything straight. One side will usually require more than the other though.
www.cubicle101.com
sikeston34m
sikeston34m's Avatar
05.20.2010, 06:51 PM
One thing that I don't like about the factory gear mesh, on brand new diffs is:
When I rotate the pinion by hand, they feel free on one side of the ring, then spin it to the other side and it feels like it's binding. There's something that isn't true from the start. The diff cup maybe?
I have thought about the aluminum cases and the diff cup. The diff cups that I have found, only have a cutout to accept the spider gear pin.
Are there any aluminum diff cups on the market that accept the bigger, beefier carrier found in the stock E Revo diffs?
sikeston34m
05.20.2010, 06:56 PM
@ Bondo
Your trucks are pushing alot of power. Wild rides to play with? How do they handle?
I like the idea of a Mamba Max Pro couple together with a Medusa 36-60-1500kv. I have a pair of Kong Power 6S 26C 2600mah packs that I think will work good with this.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.20.2010, 07:12 PM
@ Bondo
Wow, you think I'm pushing a lot of power ? I'm only on 3s..
You want to run 6s with plastic axles ? E-gads my friend, forget it you'll never be happy. Buy a TANK.
sikeston34m
05.20.2010, 07:21 PM
Are there cvd's available for the Slash? That would be one answer if there are issues with the stockers.
Yeah, 6S.
The thing about it is, on 6S, gear it right, conservatively around............ooooooh let's say 60mph or so. Then tame it some with the ESC settings.
Loads of power, efficiently.
