ptt81
05.21.2010, 12:09 AM
That just sounds like the ring/pinion gears on the rear diff. Sounds normal to me as long as it doesn't bind. If it didn't make that sound, the shimming inside the diff could be too loose. The only setups I have that don't make that sound are the ones with helical cut gears.
Whew! thought I got a bad kit or something. It doesn't bind at all, I can roll it freely by pushing it on the ground and it rolls a couple fts. So I should be fine moving to the next step? mounting electronics, etc.
Also I want to use the stock 48T metal spur, what pinion should I use? for 4S setup and CC 2200kv motor. I was gonna use the 45T plastic spur but its too wide and rubs on either RCM mount or stock mount, so metal spur is my only option and since i got the stock one, i don't want to waste it.
