Do you use a tire truer to make these? Anything special needed? What specifically are those traxxas rims. I also have a crt.5 just sitting collecting dust..yours may inspire me to do the same
I do use a tire truer for these. I use contact cement to clue them. I cut the inner rim lip off with a razor and sand them down a bit for the clue to catch onto something. I coat both inner foam donut and wheel. Let airdry a bit and then coat both donut and wheel again to act as lubricant and activator. Just squeez the donunt in place and dry overnite. Next day I just cut them down on the truer or drillpress.
The rims are Traxxas Rear Wheel Chrome Nitro Rustler.
Here's a quick pic of mine , how it stands now , running slash integy rear stiff springs all around , mamba max and 7700kv castle motor with two 2s 5000mah zippy packs for over an hour runtime.
Thanks for your explanation
