hoovdog
05.31.2010, 11:45 PM
Originally Posted by phatmonk View Post
Should the MMP have a blinking yellow neutral light after you calibrate the Radio to the MMP.Alll works perfect except for a small initial lag from a stop I am running a Novac 4.5 smartsence setting on the MMP and the bec is set to 5.5 with a 2s 5000 30c batteries.LVC is 3.2v.This is my 1st MMP but I have 4 MMM in use also.
I had my MMP/4.5 setup out this weekend and was having an issue of it completely cutting out completely (1-2 seconds) on abrupt throttle input (bench and on the track). Very smooth trigger was keeping it under control but obviously something is up.
Conditions:
Slash 4x4 12/54 gearing
6V BEC
3.3 LVC
Smartsense
0 ESC timing
factory motor timing
0 punch
I switched to sensored mode for today and could not get it to cut out at all. I'd prefer to run smartsense mode though.
