E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
06.04.2010, 11:07 PM
I had a CRT.5 for a couple years, essentially the same truck. For a motor I would look for a Medusa 36-50-3300 or 36-50-4800 with a 5mm shaft, preferabaly the 4800 if you plan to stick only to 2s lipo. The Castle motor may have plenty of power in your slash but keep in mind that this truck will weigh about twice as much and with the 4wd it puts alot more stress on the motor and esspecially on that little itty bitty shaft on the motor, 5mm is prefered over the 1/8" shaft. Neu motors may be expensive but they are worth it!
As far as tires go. Many here like he gladiators, I have never run them so IDK. I have run slash tires and they don't look bad on the truck. I did like the 1/10 buggy tires best on the truck, it's what the truck was designed to run. They look the best and the truck handled the best with them on it.
